Chris' Pioneer Spec 4 hack job
#42
The 2N5087's did not work out for a sub. Temperature co-efficients must have been different, went way squirely under a load. I have thusly swapped those out with a pair of 2SA979's a 100 volt rated part, compared to the 50 volt 2SA798, which run at 66.5 volt. The 979's lack the gain of the 798's we'll see how it affects performance.
#45
Lee you should find out why you have 66.5V. That is a problem that needs to be fixed. It should only be about 28V
#46
Unless a feller wants to unwrap 20 something wires the meter board is left in place. Not much room, but the effort/benefit ratio isn't there to take it out.
#48
Joe the only thing I can see in the way of that 66.4 volts going to the collectors is a paralled 470 ohm resistor in series with a 330pf cap. Is that enough to drop it to 28volts???
#49
Nothing you can do except use the correct device here Lee. The Spec4 has 66+ volts across the front end by design, the Spec2 has ~28V, much more normal.
Just use the rigth transistor, the 5087 gave you odd results because they were breaking down. The 798's are in the same boat. The 2N5401 looks like the only reasonable device for this location.
#51
How about a KSA992, Or Zetex 795A??
#53
Joe, the Fairchild 5401's I have have a gain of just under 200. Should be ok, I'll pull one of the 2SA 979's and see how it does.
#59
Was not a wounded cap, but a TO-126 was bad. hoking up to the AP now and enjoying the "Pig" pushing the Oppo. Sweet combination. Jan's making some coffee from resh ground beans, the kid didn't get any time. The judge even questioned on record why the case was even brought, proceeded to ream the county attorney on just who forgets their kid in the car, recited a list from a 2009 Washington Post article ranging from a rocket scientist to a pediatrician . He also mentioned there was a dramatic increase after the law stating that infants be in the backseat and TURNED TO FACE THE BACK was passed. The Wyoming law he was prosecuted under is so vague the judge said," Any parent out there could be prosecuted uner this law. Tell me County Attorney, does every parent need to be in jail? Now the state says it's criminal to forget??"
Juries and good judges are what keep us from being a totalitariain regime......
Political rant iver. The cat wants kitty cuddles and the AP is warmed up.
