- Jan 14, 2011
- Gillette, Wyo.
LOL!@
If the goal is to pop a disc into a machine (auto deck or otherwise...) that can play stand alone music files - like MP3's, wave files or any digital file format said machine can decode - then advising someone to "do" an audio CD is not proper advice. Lee wants to to host the highest quality music files he can burn to a data disc. That's NOT a red book, Audio CD endeavor.
Jer, I sure like what you did on the LaatschMusic drive. Shpongle and Steely Dan are exceptional SQ..
He wants to be able to play it in the Oppo.. does that support other formats or not? If it doesn't then yes audio CD is the right answer.
If you had read the whole thread you'd know Lee wants to play the discs in both the Ford Ranger & the Oppo.
As wave files ... ideally sourced from high quality FLAC files.
Oh yeah.. definitely. I can't recall which, but they either came from HD Tracks or I might have recorded them via Goldwave and the Xonar.
Sooo.. what can your oppo play as far as formats? Seems from reading here that is the least common denominator as far as what we should have you set your Nero to.. Nero's great software.. used to have it here til I went all Win 10.
The Ford doesnt do straight digital. Well, it does play wav...
^Hoodoo^What's the difference between redhook, HDCD, or SACD? Sampling rate?
Nero Platinum is pretty instinctive....Burned 2 already and they work in the Oppo and the Ranger...
Audio CD..What layout/disc burn type did you end up using?
Audio CD..
