"WOPl" -ing my Phases
I have 3 PL 700's. My first is a 700 (not B), I was told it was used by The Who, I bought it from "Triumph" in Toronto. It blew up once on me, years ago. I dragged it from shop to shop before I could find some one to tackle it. The pl 909 outputs were available at that time.
The second, A PL 700B, was bought "as is". It smoked the previous owner's speakers. I checked all the outputs, and found only a loose screw on one power supply cap. It worked great for 20 years before going T's up, taking out an expensive JBL 12" mid bass driver. I put Joe's board in this amp, replaced power supply caps and all outputs with 'ON' devices from Newark.
The third is another mint condition 700 B, hardly used, completely untouched ( one bulb burned out). I'm keeping it as a spare.
I considered bridging the two 700 B's to drive the new subs, but have come to my senses on that one. The old 700 driving the subs now has not been WOPLed, but I think the max power output is ultimately limited by the power supply rail voltage. If I upgraded the old amp, a power increase from about 400 W/ch to maybe 460 or 475 is still less than 2 db.
I was using Cerwin-Vega Sensurround folded M horns (L-48-se). Very efficient 400 W drivers, lots of output above 40 Hz, mostly distortion below. My new RCF subs are rated 1500 W pink noise, 3000 W 'program', in bass reflex cabinets. They have a max cone P to P excursion of 50 mm but are considerable less efficient than the old C-V's.
I have an L E D power meter on the sub amp and have seen the highest led (512 watts) flash occasionally, I think this is pushing the amp to hard. Would you not agree that an amp like the Crest CA 18 would be a great amp for this application, keeping in mind, the large listening room (24' x 36', 17' ceiling), and the audience is mostly insane (me).
Is the Crest made in China, is there such a thing as a CA 20? Is Crest that much better than QSC (5050a) Crest claims a damping factor of 800, and 15 db better S/N.
If you read this far, sorry for being long winded, Regards, Peter from Canada
