Russ' Phase Linear 700B Going Fully Comp!!!!!!!
Getting some pre-White Oak conversion testing....
This is the test mule for the new back plane boards..
Frequency Response (SUCKS)....
THD & N Left Channel
You need to dust Dude! :rabbit:
attachment.php
Yep, the very one the factory used...
OH, I do that during the spring monsoons, stays that way for a few days then..
That's crazy... how did you acquire that????
From a former Phase Linear employee whom shall remain un named. Same guy I got the Phase linear factory BPI 2,000watt load cell, even has a PL property sticker on it.
Residual noise, (sucks)
Other measurements..
Well, beins this one is getting gutted and going back with White Oak everything, shall we throw some 10 amp fuses in the rails and a 15 in for the mains and see what it will do on 4 ohms??
Keep the fire extinguisher handy Brother
You just want to see some smoke don't you? :violent2:
How long does it take to get your readings? If you do push it - GOOD LUCK and wear protection.
Oh yes it will Ron, the AP don't lie....
Nav, I'm just awfully curious when the power supply will start to drop out....
