Australia
Deep Purple - Machine Head - Sourced from Quadraphonic Vinyl on my Thorens TD 160 Super, Played back at 24-bit/96khz wav file (you could call this a 'needle drop'), oh yeah, and the mix is different in certain places when compared to the original, I found that most interesting. I know the album back to front and there are some parts/tracks from the master which don't even appear on the cd.
pennysdad
In witness protection.
I remember it well from my quadraphonic days.
Australia
Deep Purple - Who do we think we are - Vinyl sourced from Thorens TD 160 Super - Playback at 24-bit/96khz wav file
Australia
it's just that I'm not that familiar with converting to wav, as on a Mac, we convert to .aiff.
the only time I've seen reference to bits'n'khz is when I convert to .flac
just educating myself.
Wav file is the initial format that the needle drop is recorded to with pc's, in your case it would be aiff format for macs. Both are lossless formats and space can be saved by using lossless flac codec at the end of the day.
I have over 250 needle drops which I need to split into tracks, found some amazing software to help with this, but at the end of the day manual adjustments have to be made, big job but will be nice to have tracks to select and randomize, not to mention a subsonic filter applied to protect those oh so precious jbl 4311b's when played at high volumes.
Australia
Also, 16-bit/44khz is cd standard, 24-bit/96khz is higher resolution and i use this because its the highest my soundcard supports, takes much more disk space but flac helps with that.
Australia
John McLaughlin, Al Di Meola, Paco De Lucia - Passion Grace & Fire - Thorens TD 160 Super to PC 24/96
you're just jealous you don't have one.....
I just use half-speed recording.
I had grandma record an eight track of my records for me years ago and somehow it ran at half speed during the recording, leaving me with
Alvin...ALVIN???
ALLLLLVINNNNN!!!!
