Nick Danger
- Apr 28, 2013
Failure~ Fantastic Planet(CD)
WTF are needle drops???
Deep Purple - Machine Head - Sourced from Quadraphonic Vinyl on my Thorens TD 160 Super, Played back at 24-bit/96khz wav file (you could call this a 'needle drop'), oh yeah, and the mix is different in certain places when compared to the original, I found that most interesting. I know the album back to front and there are some parts/tracks from the master which don't even appear on the cd.
Deep Purple - Who do we think we are - Vinyl sourced from Thorens TD 160 Super - Playback at 24-bit/96khz wav file
wav or flac?
Most definately a wav. Will flac it later if desired.
it's just that I'm not that familiar with converting to wav, as on a Mac, we convert to .aiff.
the only time I've seen reference to bits'n'khz is when I convert to .flac
just educating myself.
Also, 16-bit/44khz is cd standard, 24-bit/96khz is higher resolution and i use this because its the highest my soundcard supports, takes much more disk space but flac helps with that.
mine does 128-bit/1GHz
LOL, you would need 4 solid state drives running in a raid array, and if you are lucky that might just keep up with the amount of data being laid down during recording.![]()
you're just jealous you don't have one.....
I just use half-speed recording.
