Stephens Phase Linear 400--In for the works.
Getting closer. Gonna see if an outboard power supply in a toroid version is going to lower the noise floor.
Cool. So what Volt Amp rating and rail voltage are you going with? This sounds like a fun experiment.
Those Holden and Fischers I've got. Don't know the VA rating, rectified +/- voltages are 92.3 DC.
If the hand slips-----DINNER IS SERVED!!!!
wELL, i WAS TORN between sex and food, ya know how that goes...
Beins the heat sinks are where we start with Joe's backplane boards, I shut down when the copper arriveed to do the heatsinks. I taped as much as I could as soon as I unwrapped it. Just running your hand accross it.
Also, I had proposed to Steve that for critical listening ( IE-NOT mach 8) that I could add a couple positive speaker posts in a bypass situation. The RCA in holes are now occupied
by the bypass posts. The new RCA in's will be located above and below the bottom standoff for the board mount.
Gonna run these jacks..
No, but the shielded pair won't be but 3" long.....
Cut, drilled and beveled the blanks..
Managed to get them bent tonight too. Getting more consistent all the time...
I don't think Joe is into Ghirardelli's anymore, probably onto bigger and better, don't know what that would be though, these folks been at it quite awhile.
The storm has hit. Got a couple wells to check then wait for the pumpers to call in with all theit problems. There will be very few, or a lot. Seems to be the way it works.
I never get tired of Ghiradelli's Lee, excellent chocolate. Was wondering what teaser Dennis was talking about :-)
The chocolate appears prominately in both pics, so I assumed it was that. Nothing else in the pics I could see would be a Joe teaser.
