Got some Carver equipment that needs work
Who here is the Carver gurus? I asked Jer about 1 amp but I have a preamp and another amp that need attention also. Caps 'n such. Got the stuff today and though usable (except 200T which I knew needed some sort of repair), I am bummed. I believe these units were all Kimber Kable test units
M1.5T subdued buzz in speakers only when plugged in. Drowned out when volume is increased (I tried flipping the plug around in case it was polarity and it's not). Carver site says 2 mid size caps need to be replaced
M200T relays clicking probably caps and whatever
C1 preamp, tone control does not work right, caps need to be done
I could trade the M200T towards the work on the other two, also have some other stuff
PM me please if interested
Did not feel like hooking the WOPL400 yet and just been listening to this system. It has a very warm sound to it but does not hit with the authority of the WOPL400 which kills it for articulation, impact and detail. This M1.5T is like a comfy pair of shoes though... at very high volumes where the PL starts blowing fuses, the Carver wants more and the CV's seem to get along well with it. It's a tossup. I am sure once the M1.5T is redone, it will sound exponentially better but will it make me blink with a rimshot at Mach 3? That remains to be seen, I love the PL
I really like the attenuation of the C1's volume knob a lot. I may try it tomorrow with the WOPL400, I am sure the tone knob issue will be irrelavant as I never felt the need to use any tone with the Phase Linear
I think this M1.5T needs to be Laatchified
jbeckva
Admin/Server Dude MAA Guy
WassupYa Mang?
Laatsch has all the equipment he needs. He needs foldin money....
Aye... "Jer" too...
Hey Ron, you know... I was readin' the 400 manual the other day on a hunch. Says in the manual that up to a point the 2 line fuses were 5 amps, then PL started to put in 8 amp fuses. Sooo.. might want to go for the 8's in there (PL also recommended under no uncertain terms, 8's for 4 ohm loads). Could be a quick win for ya...
Here's the section here...
Maybe that's what these guys meant...
PS Jer, why can't I post past any attached image STILL???
Aye... "Jer" too...
I will get some 8amp fastblo fuses then, what voltage? The same 250v? As long as you feel these are safe to use, I will try them. The CV's are 8ohm
jbeckva
WassupYa Mang?
250, 125 minimum. Make sure if they are the AGX or AGC fuses, as I can't remember which 400 I swapped the fuseholders with AGC style. 8A's on the two rail fuses, and a 10A on the line (that's the one closest to the left side as you're looking at the front).
In your application, I'd also recommend you get a couple of fans back there for better thermal handling (keep in mind that 400 is the "4 fin model", which won't dissipate heat as well as the "8 fin model"). Something like this here..
http://www.mouser.com/ProductDetail...aHJACUewmQ==&gclid=CKnz5pHegrsCFUzxOgodzQsAmA
Get a couple and with some hardware you ought to be able to make 'em fit.
Hey Jer, you have a 8amp in the line fuse position. So I should get a 10A for that also? Is that fastblo also? Heading to the Rat Shack this afternoon
I tell you what Jer, the PL400 really likes the C1. I did some messing with it and now the tone control works, dirty switch
Their packages don't say AGC or AGX, just want to make sure I am getting the right ones
jbeckva
WassupYa Mang?
If the length of the 8A in the line position is the same as the other two, you're in luck because then all three are AGC's (and you can find fuses for them anywhere..). Yeah, 10A for the line position, 8A for the other two.
Jer, the far right fuse holder sticks out, the other two are flush. I am guessing the spring inside probably accomodates both sizes. Fuses are cheap, I will grab about $10-15 worth just so I have them on hand for the future if the need arises
Got your PM, you rock Brother
Amp slays now Jer, thanks! Did not seem to get real hot either when I put the gas to her for a few minutes though I only took her up to a hair over half volume indicated on the C1 preamp out of an abundance of caution. Still mounting a few clip on fans though this week. Any ideas to increase surface area of the fins though? Maybe weld or lay a plate across the back??? Or is there kits out there that can be modded to add surface area?
