- Jan 14, 2011
- Gillette, Wyo.
Amen Dennis a hell of a core group already...
So I am getting ready to put the new outputs in. Cleaned up the back panel and remove all that sticky compound. I also pinched the pins a little to tighten up the contacts. I have some arctic 5 thermal compound left over from a redo on my computer heatsinks. My question is whether I can use that type of compound on the amp. I know there are some issues with some thermal compound that conducts electricity and would be bad for outputs on amps.
where he inserts a 200 ohm resistor in series with the outputs, but that doesn't have the immediate visual indication like the bulb does.
A rail fuse going in a 400 is not that rare an occurance. What are your offset and bias measurements?
I love this amp
