VintageShadow
it IS pro stuff....
New mastering tapes are hard to find and very expensive.
I know it's PRO stuff, and even not pro ones are not very cheap anyway... I'll stick to my cassettes then
it IS pro stuff....
I personally stay away from the MA's.
I personally stay away from the MA's. You can generally see the white residue on the tape roll while still in the wrapper.
Ah... White residue again?
Is that what keeps you pilots awake on those long flights?
Ok, this is the deal
If you Brothers dig obscure garage, I made a recording of a test pressing of Burnt Suite which was a Connecticut local band. The regular lp (if you can find it) sells for $200-300. I used a USB TT to burn it to disc straight through w/o making "breaks". If someone here is willing to make a tape of it to make available to members here (either CD-R or cassette), I would be willing to send my master disc for someone to do their magic, Nando?
This is an album you all need to hear and I am willing to share
Here is what the cover of the lp looks like, it was released on the private BJW label in 1968
