- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
Quick update for you folkses...
Got these in today.. compare with the ones pulled...
Ready for the transplant. Figured I'd leave these where they are at until I get the stuff from Lee (Looks to be ETA'd Friday). This weekend, work begins in earnest!
They look almost as big as a beer can...Quick update for you folkses...
I don't plug my fans into that receptacle anyway.
A four poster, that is very early Jer.
Nav, here's that bolt that was in the middle of the xformer plate. Brutal, heheh
I guess I can stop worrying now. Lee may have had this one pegged from the beginning as a means to support the transformer in a rack configuration. What size is the hole? A butt plug may fix that.
Mine's a four holer Joe. Does that means she's old?
And continued to downgrade their signature product...
Yes, they started with 4, went to a tripod later and eventually settled on only 2.
You are doing such nice work, I almost want to put a glass case around it...
Why is that Joe??
I was thinking of taking advantage of that. Leave the top 2 "in", and use those like telephone poles - suspending the AC related runs from the tops. Might have been a good idea, dunno... Ended up with this here. All AC is being routed across the top. If along the bottom, my thinking was that it's crossing all of those control wires from the outputs to the driver board.
That is oh so true for the mainstream, unfortunately. I don't follow that mindset myself.A lot of that behavior also stems from the disposable society we have all become. Built to last is no longer a requirement or a desire.
