- May 1, 2013
- Australia
- Those who enter the man cave will get WOPLed
sorry, din't notice it was a 3020...
here's the twin torroidals inside of one of my amps.
Are the dual transformers the reason why I noticed the NAD 3150 sounded so nice?
Derek, those won't hold a candle to a new WOPL. You are going to be truly amazed...
Something happened on it's way to the States, it morphed into a 700 chassis....
Don't be sorry, I'm ecstatic....
no.... you're being too kind.
I ph*ked up. that's all there is to it.![]()
If that's a F&^%$# I'll Take those all day!!
BD , seriously you had no iudea what you had. I think this a 700 Ser II chassis. Just checked it against a Ser I heatsink!!!!!!! It is a Ser II!!!! Which means I wonm't have to gut a 700B to send to Joe so he can start on the 700 backplane boards!!!! BD, you done REAL GOOD!!!!!!!!!!!!!!!
Ser II because it does not have the Normal/Direct switch hole and it has "Press Nuts" for the top and bottom covers!!!!!!!!!!!!!!!!!!!!!!!
It did not delay D2's project in the least. Ed is sending me 2 ---400 parts only chassis so it's all good.
