 - May 1, 2013
 - Australia
 - Those who enter the man cave will get WOPLed
Earth to George, Status update please bud
			Earth to George, Status update please bud![]()
Put it this way.....
If 'they' don't come around at 7.00am tomorrow morning, then I may just get away with it.
BUT, if there's a knock on my door at 7.00am tomorrow morning, then I'll be going to the lockup pro'ly 'till Monday morning and then go to see the Judge. I think that's how they usually do it.
Either way, I'm not opening my door tomorrow, and just hand myself in on Monday, and take wot comes.
.... just relax as much as you can and enjoy those tunes.
yep! just been listening to Tears for Fears most of the afternoon, after doing some vacuuming.
damn that kitty litter just gets everywhere. you'd think the kids would've learnt how to wipe their paws after being to the box outside by now. no way!
They do a good burn out after jumping out of the litter box. Wouldn't bother me, I'd do anything to have a kitty at the moment but its just going to cause me stress with the real estate and body corporate. I simply wouldn't trust anyone minding them for a day either. Maybe when I move.
Listening to Eric Clapton Slowhand for the 4th time this week, the Nakamichi 480 is giving me hell with slight tape dropouts during recording so I'm using the JVC TD-V661 dual capstan now, don't have the time to mess with the nak, put so much into it during the week and its still being a bitch. I must give credit to the JVC as it has been flawless and always does a good job, never lets me down.
I have a bunch of other Clapton records to record tonight, all near mint, ear candy and the first listen is going to be awesome as I have not heard them yet.
same with my 660
i've put a lot of effort into that one, and had it running perfect.
tried it again after a day, and the same speed problems came back.
i guess i'll have to get a new belt set ($60) afterall.
bugger!
Try a drop of oil down the capstan motor shaft, run the deck so the motor is pointing shaft up so the oil can go down into the motor. Either that or de-oxit. I normally just clean my belts with alcohol or if I want to tighten them, I take them off, boil a jug of water, put the belt in the boiling water for 5 minutes, then take it out and put it in the freezer for 10 minutes. Sometimes it works, sometimes not. Have only destroyed 1 belt out of doing it to 5 others. Will see how the 480 goes with those new transistors when they get here from london. Until then will enjoy hassle free recording with the JVC.
i'm just as happy to push it all aside, and just use my iMac. sounds just fine, and so much more to choose from considering the size of my .flac library.
I have a Yamaha KX-300 Deck here which I need to clean up to be photo worthy. Basic function tests passed, have not listened to it yet. Need to get motivated and work on it. Amorphous Head, HXPRO, Dolby B/C/MPX etc, single capstan, knobs are missing on it (big deal). Pinch roller still rubbery and consistent. $5 from the dump market, couldn't help myself, tape deck number 17![]()
just looked it up.
that's not a bad deck. it's got lots of switches and labels that make it look quite techie.
you'll have to find a remote for it now.
you can find the user manual here:
http://www.nodevice.com/user_manual/yamaha/cassette_decks/kx-300u.html
to be honest, the first few "natural sound" models were just a little too lifeless for my liking.
even playing quality recordings with the "Dobly" pressed out on playback, still wouldn't give the sound the presence I was listening for.
call me old fashioned, but i like my decks to have a bit of weight to them too.
the yammies were just too light weight which to me meant compromise on build quality somewhere along the line.
Here's a Sonics 800x like wot I got.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=330967407923&ssPageName=ADME:B:SS:AU:1123
Now I think this guy is getting it confused with the 600x, which is a 3 channel amp with the built-in active 3 way x-over, but the 800x is a Bryston 7B. (800W Monoblock) which as I've stated elsewhere can be converted to stereo very easily by bypassing the back panel mono module.
So if anyone's interested in a cheap 7B, here it is.....
