- Jan 14, 2011
- Gillette, Wyo.
I own a small piece of 110 of them. And no, my gasa is not free.
Does this mean you charge for farts????????![]()
I'm wondering, being so freakin' cold where he is, if he passes liquified gas?![]()
Ok, I have read through this thread and there is no way to split it into coherent thoughts? The subject matter drifts like the wind or should I say one of Lee's farts.
Caryy on as I have no intention of trying to sort this mess out. I'll only say why does everyone want to listen to loud music? I usually listen to my music at low levels so my sound system needs to sound good with the volume control at 8 o clock. If you have you volume turned up to 11 and you are hearing distortion it could very well be you speakers and not your amp and there is much more latitude between great speakers and torpedo speakers then between a wopl and a Pio 9500. I have a pio 9500 and mine sounds fine on my speakers. In my estimation an Wopl is just going to burn through your 3 pair of speakers in about 10 minutes max.![]()
Actually, I would freak if I witnessed a pair of speakers with their guts hanging out from cranking it and a transient discursion hit. ......... And that's the Canadian way.
You get used to it after a while Nando....
Nearly ALL of my speakers have been there some time or other.
Here's one I 'prepared' earlier...
It's the only way to find their limits!
.... and that's the Australian way. Heh heh heh.![]()
You just lost another star off that energy rating george![]()
that was the last one, too!
damn!
Steal one from your washing machine or fridge then, you need all the reserves you can get.
Got my power bill yesterday, $350 for 3 months, no complaints there, much cheaper than summer bill of $550+
hmmmm.... never thought of that!
yep! the fridge has two stars left. i'll grab one of them....
if the sun could get to my place, i'd go solar in a flash.
.... but the sun just doesn't shine here.![]()
The only sun that comes in here is from the window opposite the staircase, and its never direct. I have the windows covered up on the ground floor, true man cave style, the internet router makes a good night light, strobe light if its transferring heavily.
Where on that continent can you get away from the sun?Is everything all electric? My electricity bill ranges from $50 a month in winter to $100 a month in summer. Natural gas bill ranges from $100 a month in the dead of winter to about $25 a month in summer. In my part of the world my furnace, stove and water heater run off gas and my a/c and all appliances run off of electricity. Electricity runs about .10 per killowatt hour here.
Its just over 30 cents per kwh here and they just more than doubled the fixed "supply fee" just to add more pain. To make it worse I live in a complex which only has 1 meter per unit so that means no off-peak hot water, you have to have 2 meters to get that and apparently there isn't enough room in the meter box, and it costs a lot of money to get one installed anyway.
Feel like a vegetable....![]()
