pennysdad
 - Feb 27, 2013
 - In witness protection.
 - I've totally lost the plot....
BD
Unless you are using electrolytics in your crossovers, which you are not, the polypropylene itself will be just fine. Your speakers will have mechical limitations that will come into play long before (that is, at lower frequencies) the ESR characteristics of a polypropylene cap come into play.
Bypass is used in circuit design because the electronics often has response out in the multi-megahertz range where these ESR characteristics come into play.
That is why you do not see bypass on the main capacitive elements in a speaker crossover.
On the other hand, it does no harm.
JBL have been using bypass caps for about 30 years now.
I was reading the following thread, (and all associated threads), here:
http://www.audioheritage.org/vbulletin/showthread.php?3555-Bypassed-and-Biased-Capacitors
It's no wonder I'm so confused....
(binkey)
 (my fav)
 (who's this?)
