- Jun 11, 2010
- Powhatan, Virginia, United States
- WassupYa Mang?
What is taped to the back of it??
That's the support for the transformer while she's on her back.. temporary til I'm fully done..
Which speakls to which amp???
Wait till ya start breaking light bulbs and flatscreens....
Don't want to go that extreme.. ears'll hurt first.
Guess what drivers I just put in, with NO problems?? I figured it'll work or it won't so what the heck. I like the sound of the 15024's with the 21194's instead of the 410's - Just seems clearer to me.
meters still fubard... I'll take another stab at those another day.
Check for oscillation on the lower half Jer, you will not hear it but you can see it on the scope. That is a risky combination, 2 poles at the same frequency in that configuration. The oscillation will be in the high 100s of KHz range and may break out sporadically.
What 2 poles???
You won't see it on a signal that big Jer. If it materializes, you will see it on a signal of a volt or 2. A square wave input will show it up as ringing on the negative half
