- Jan 14, 2011
- Gillette, Wyo.
Gotta call Bs on this.... Link courtesy of Przem
Frequency response and distortion figures of amplifiers are normally measured at 1 Watt. The maximum power of an amplifier is normally measured at 1kHz. At 20kHz most amplifiers can not deliver more than 1/4 of the power quoted at 1kHz as in the graph below. The limitation of power restriction of amplifiers above 10kHz is described as Slew. It is not possible for any electronic circuit or individual component, transistor, FET or mechanical switch to be able to turn on and off instantly at the speed of light. Slew is the highest speed an electronic circuit, transistor or FET can change from on or off.
Volts / micro second is Slew rate. With an amplifier of + – 60V supply rail, the leading edge of a 20kHz sine wave would have to change from 0V to 60V in 1/80,000 of a second ( 12.5uS ). Therefore it has to have a slew rate of at least 0.2V / uS to reach 60 Volts in time. But if the amplifier output can only change at 0.1V / uS the maximum voltage it could reach is 30V which is half way and therefore 1/4 power.
Many amplifiers that use power MOS-FETs have very high slew rates and are easily capable of delivering 20kHz at full power. But many amplifiers that use output transistors are restricted in being able to deliver full power at 20kHz. Slew can be intentionally applied in a driver circuit of an amplifier (dominant pole capacitor) to insure high frequency stability and freedom from internally generated parasitic oscillations.
But there is another unique problem of slew that is caused by the internal limitation of one or both output transistors not being able to turn off as quickly as they can turn on. This problem causes a large quiescent current cross conduction through the output transistors that generates extreme heat. An amplifier with slew limited by output transistor cross conduction can be destroyed by high frequency oscillation caused by a reactive capacitive speaker load or Rf (radio frequency) getting to the input from an external source.
Music power bandwidth
