frhodes
The previous owner of the PL2000 pre amp I purchased had previously sent it to a technician for repair of 2 items. The phono stage input was not working on the left side and the on/off switch had broken. The tech came back that he could not locate the fault on the phono portion and recommended a small phono preamp. After gutting the rotary portion of the switch he installed a toggle switch by drilling a hole in the back of the unit. (he should have put a switch on the cord or bypassed it and recommended a power strip)
I contacted Carver Audio (who specializes in Phase Linear) in Oregon who after 3 days said there was nothing they could do about the switch. (Unobtainium dual gang 50k audio taper 1/4" board mounted d-half moon shaft.)
My Electronics Guru (brother-in-law) found the faulty capacitor on the phono stage, replaced it, and not one to give up, located CTS same era switches with a different taper and shaft. Removing the rotary portion of the donor switch he transplanted it onto the original switch. Surgery at it's finest. The pre amp now functions perfectly.
I now have a hole in the back of the unit. If anyone can recommend a headphone jack circuit let me know
as I would like to fill that hole.
Pictures show original gutted switch, surgery, patient in recovery, switch re-installed.
