Zach C.
Yay!
I am extremely happy to announce that this thing is up and running!
I couldn't sleep, so I'm working on it at this obscene hour. Even I don't get up this early.
Right now, I have Don's board installed as recommended in his instructions, and it's coming up fine. Since I did not check at every step along the way, I'm not 100% sure what made the difference, but I suspect either the AC rewire, or the bridge rectifier caps.
What I've done since starting this thread.
1) Replace Q4 in both channels due to having physically broken one leg in Q4 left channel. I'm positive this was fine before, and I broke it during this process. The amp had been running fine in stock config. DC offset was already low at around 15mV in both channels- now it's 7-10 or so.
2) Rewire AC as per Joe's recommendation, routing all A/C (including that for Don's board) along the top of the chassis.
3) Install 4 .01uF ceramic caps on the bridge (removing the original- C25)
Basic testing after this point revealed that the meter slam I have always had was now gone- not sure why other than improved stability.
4) Install 4 .33uF Poly Caps from DC rails to common at outputs as shown in mlucitt's drawing.
At this point, I checked to see if the amp would come up w/o the factory zobel- i.e. with the output open. It did.
I then reinstalled Don's board as per the provided instructions. The amp came up just fine, and the relays clicked in.
For what it's worth, the board I got from Don has the 4.7r resistors in it, though this seems irrelevant to anybody except possibly Don.
For now, I think I'm going to run this thing as is for a while to be sure everything continues to be cool, and the look at going to a star ground. If that proves out, I'll go ahead and install the White Oak driver board- it's all assembled and patiently waiting.
As soon as the wife wakes up, I'm hooking up speakers. Woot!
I owe a huge thanks to all who contributed to this repair!
THANKS!
Zach
THANKS!
Zach
