speakerman1
 - Jun 12, 2010
 - OZONE ALLEY MARS (Visitor)
 - Wasted Days and Wasted Nights
I use the microfibers more than the diaper. There are different grades of micros. They start costing like 3.00 a piece. Don't use fabric softener it cuts down on absorption. I use Ivory Snow or Woolite when I have it. I hand wash. Then throw in the washer on hot. The wallmart ones are fine after you wash them a couple of times. I use them to do the first step when I spray the Phoenix. Hit it with the disc brush and phoenix sprayed on the brusch. Then I spray the record with Phoenix and use their cloth it is a very fine micro. I will play the LP a bunch of times to see which process works better. What % alcohol?
