- Mar 18, 2013
- Coventry, CT
- Fondler errrr... fan of all Nav's avatars
I ended up trading for jeanmarie's 400 and trying to find who built the Amp. I think it was a Eric? Anyway, love the Amp but wanted final testing results of THD + N and also how the micro switch on back for meter sensitivity works since I see no difference in position
Amp sounds great as expected. Midrange very forward in this build. Trying now to design and build a new rack as my existing one does not have room for my msin amp that Perry built 700 series II using Rev G board called Sabbitha
I got the 400 to run a set of JBL Control Monitors purchased from Channel 30 in West Hartford about 10 years ago. They are rated at 375wpc so perfect fit for the 400
I have the 700 controlled by my Perreaux Class A SA3 preamp and plan to use an Adcom GFP 1A for the 400. Any ideas how to jump the signal from the Perreaux into the Adcom?
Been awhile since I posted because I couldn't login which Jer helped me after I got ahold of him on FB
Eric, if you see this, could you post final test results after you finished the Amp and also explain the meter sensitivity micro switch?
Thank you, here is the Amp doing what I do. Also have to name her. I don't know the original woman's builders name from PL
Guess mp4s don't load here??? Sorry no vid
