Oldskoolfan
Since that's all it is, I can set a delay to the rear amp with a DSP, yes?It gives you a delay and you get an echo just millisecond's behind the original signal. It's KIND OF a surround but some don't consider it surround.
Correct ! Sorry for mismatch .It's reverb as well, not jjust a delay, but yes, an external process should be able to do the same thing (I used a pair of MXR175 delays for this in the 80's . . . ) The manual gives a pretty good idea what is going on. There are two selectable delay times (varies by S/N) and a regen control to set reverb level.
And, to clarify a prior statememt, the 4000 was never made without the amp - that was the 4000t. Yes similar, but considered a different model by Carver. (I use the amp in mine with no issues . . . )
But, unless you did those things one at a time and listened/tested, it's hard to know what made the biggest change.I'm convinced a recap, regulators, motorized blue velvet volume pot, and new RC4136s made a noticeable difference in sound on my C-1. I haven't done the RCA jacks yet but that's my next move. The old ones are cheap and nasty.
I now have the RCA panel replacement boards available now for doing that RCA jack conversion when you are ready. Makes it easy.I'm convinced a recap, regulators, motorized blue velvet volume pot, and new RC4136s made a noticeable difference in sound on my C-1. I haven't done the RCA jacks yet but that's my next move. The old ones are cheap and nasty.
Good question Kyle. High quality from Neutrik-REAN. Others are available (mostly from China) with lower quality. These are what Perry is using presently on his rebuilds.
I'll vouch for the Rean components. Cheap n good.
I have Perry, got to gin up a web page but they are listed on the site for a while now.When you have to get 13 white, and 13 red , it adds up quick. I have to charge an extra $100 to pay for the 26 jacks (over 60 with shipping from Mouser) and cutting and stripping/tinning about 100 wires to get them all installed but the results are great. I guess you don't need my measurement of where to cut the C-1 jack panel to use on the 4000/4000t..... Are you going to advert these on your site Joe?
Much better than $60 per jack I think.Cheap? I spent a lot on doing 2 C-1's and a C-4000 proto....... $60 for each preamp jack set, plus 2 days labor for the wiring of each unit....
