Look, Ma, No Computer!
Bob Boyer
Chattanooga, TN
Just a 2 TB Glyph drive between a Pro-Ject DAC and a Po-Ject Streamer. Glyph plugs into the streamer, streamer plugs into the DAC. Both are powered, Glyph draws power from the streamer via USB. Pat's old iPad controls it all through an exclusive web page. I actually don't miss the JRiver software on the computer.
It would be lit up but I'm watching the Ohio State game on TV. Will report on sound later tonight or tomorrow. It already beats a large computer monitor hogging space on the shelf.
Looks like I could have dusted the tuner first...
I like the concept. I run a PC and monitor w keyboard and mouse. Sound is better when I remove the monitor from my desk as the speakers sit opposing it somewhat. I have used Foobar Con Pro in the past and that way I can play whatever I want on my PC and use an android tablet or phone for the interface. Had some trouble with it finding the PC last time I used it because I had not re installed the server side software. I need to get around to doing that. Very nice dust. That dust should feel proud sitting on that Yamaha. Yamaha Natural Sound equipment is very good in my opinion. I am guessing that tuner is a good one? Not familiar with the T-7 but I damn sure like the analog numbers and all running across like that. Damn, I just did a bit of reading on the T-7. Now I want one! Killer Tuner @Bob Boyer !
I'm thinking about using that HP mini PC as a streamer, there's a web interface plug in on github for DeadbeeF, or I could do the same thing with Kodi.
Thanks on the tuner. I found it from my local repair guy - Scott Grammer at Red Bank Vintage Audio. He has a few pieces up for sale every now and then and yes, it's a nice tuner. Maybe not a T-1 or T-2 but pretty nice nonetheless.
And on to a quick report on the sound of this rig. I think getting the computer out of the chain makes a positive difference. Subtle, but there may be a bit more open even than the jump from the Tascam to the powered Pro-Ject DAC. Listening to my Kruger Brothers album and instruments are a little more "there". Cello especially. Kenny Aranoff's tympani on John Cougar Mellencamp's Crumblin' Down - even on a file from vinyl - have the needed weight. Richard Thompson's percussive guitar on his Classics II album is in your face, dead center; Johnny Cash is right there with Rick Rubin in Cash Cabin on American IV. It's doing everything right that I can tell.
Operationally, you have to be careful if searching while something else is playing as it can easily head away from the file being played. And it would be nice to control volume from the web inteface without diving into the setup memory, but it's sure nice having the file list on a screen in my lap istead of over there on the shelf...
A+ on the setup, especially at 45% of list price.
Can you assign a level to each track so that as it is random playing all tracks play at roughly the same output? Like an adjustable pad attached to each file?
There’s a need…
There’s a need…
Indeed. If there is a method, I've not found it yet but I've not played with it too much. I've tried leveling all files but the differences between Amadeus', Adobe Audition's, and my purchased file's loudness algorithms mean that things still aren't perfectly leveled and I had to adjust Media Center's volume even on the Macs. I'm not sure I have the patience to match volumes on 8,000+ files if I had the life remaining to do so. :D
Yeah doing it up front isn’t reasonable but as they play, they could be tweaked potentially. I play my ripped CDs on random in work and some material is significantly louder than others…
Nice setup! I am also a fan of a no-PC digital system. I have my streamer interface running into my DAC. I can control it with the streaming apps on my phone, which is very convenient. I also keep a USB plugged into my DAC so I can connect my laptop if I need to. My streamer also has a USB port on the front which is very convenient for plugging in an SSD drive or a memory stick.
Thanks! This one has a front panel USB port, as well, so a computer/SSD/stick hookup is not out of the question. I have the streaming apps on my phone but like the larger screen of the iPad in the web browser (it's too old to run the apps).
I bet the pro ject streamer has a replay gain function.....
I found one - need to check it out to see if it can respond dynamically or if it's set it and forget it.
Edit: noticed for the fist time last night the difference between mix tapes digitized from the 15 ips tapes and mixes made by editing digital files together in Audition or Amadeus and leaving them in the digital realm. I have both copies of my mixes - the digital mix and the 15 ips copies of the digital mix and can now tell the difference. It's subtle, but it's there.
