Passive Horizontal Bi-Amping question
Gibsonian
#21
The gain of 400s, 700s (with pots maxed), Model ONEs (also with pots maxed or bypassed) is IDENTICAL. The only difference is the max power each can produce before clipping
Isn’t the input to achieve full power the same on both the 400 and 700?
#22
No it is not, 1V in on a 400 may hit the power supply clipping limit while the 700 still has room to move and needs 1.25V to hit clipping due to a higher voltage power supply in the 700. What is true is that up to the onset of clipping, the same input level into the 400 and 700 will produce the same power output from each amp
Gibsonian
#23
Thanks for straightening me out Joe. This is quite convenient for the passive bi amper
Gibsonian
#27
Crossover Frequency
400 & 2,200 Hz
So the cross will be at 400 for biamping. The crossover in front of the mids and tweets will help consume some power but still the bass amp will be doing most of work. Be interesting to see if this improves the sound for you.
Mohawk
Ontario Canada
#29
That's how I have it, 400 on the tweeters, 700 on the woofers. Since I scrapped the passive crossovers and went active I've found the compression driver tweeters are more sensitive than the woofers so I tweaked the gain with the MiniDSP.
But since your biamping with passive crossovers this should not be an issue.
Yup, same here too.....
