Anybody have a PL DRS400?? I'm repurposing so if you need some parts, there are some good ones left.
I have one that was given to me a couple weeks ago and it needs some TLC. I just wanted it for the chassis as I want to make a load bank out of it. It's got plenty of room so I just need a few switches and a couple BIG heat sinks and some applicable resistors to be able to handle OVER 500W and I want it to be able to run both channels and also have some RCA's so I can hook up my Audio analyzer which has a built in attenuator and thats my only complaint about the Quant Asylum QA 401. I should NEVER have gotten rid of my awesome Bongiorno built custom load bank able to set 4, 8, 16 ohm testing and would handle a 500 Watt amp with both channels driven. Built in fans and redundant front panel connectors so you could monitor with a multimeter, analyzer, speaker jacks etc... The electronic switches are probably expensive too. I had to play with it for a while till I figured it out as Jim Bongiorno didnt mark much telling you what it had. I couldn't call him as he had died a year earlier. And NO, I don't want to cobble a couple paint cans together and rob my water heater of its parts (Its gas anyway). If anybody has a killer schematic for one, post it here.. I found this site for parts to build one but I don't think it's beefy enough. I will use the heat sinks off the DRS 400 and I have those AC Infinity programmable fans. Then I can paint the whole friggin thing GREEN with some random flashing LED's to make dipshits ask dumb questions.... :)
http://www.pmillett.com/dummyload.html
A cheap load bank can be made with hot water tank heaters. Home depot has a 240 volt version that is very close to 8 ohms. Downside is they have to be submerged in water or they burn up immediately. A 5 gallon bucket with a metal lid works well.
My exclusion of paint can cobbling includes 5 gallon buckets, water heater elements and 3000 1/4 watt resistors wired in series, parallel or otherwise. I want it to blend into a test bench and require pretty much zero maint (i.e. changing oil, water, 40:1chaninsaw juice etc etc etc). I don't mind spending a buck to make a useful non hacked piece of test equipment that works like a REAL piece of lab hardware. Hiding it in a repurposed amp chassis is perfect, easy to blend in and you can stack test gear on it for easy access. But hey, I'm weird. I even bought a new lamp shade for my DBT because they look ghetto. If yer gonna test a $4000 amp/preamp, spend a few bucks and make it LOOK like you know what yer doing.
After a few hours we found it. Its for the Model 240 and 250. It's a copy of a copy of a copy. I've tried to enhance it a bit and if it's not good enough get me your email and we'll go that route..
Lee,, if you want the clear copy, I found the link to the thread you were on at AK.... I'm going to build the 250 clone but I will run 2 channels with the other two parallel. I ordered the resistors yesterday and I need to figure out a switch since it isn't annotated on the schematic. I'll wire it for 4 and 8 ohms, I never found a use for 16 ohms. Do you know what switch they used. GOOD ones, none of that Cina shit.
https://audiokarma.org/forums/index.php?threads/solid-state-bpi-analyzer-3000c.402220/#post-5109115
Perry, I'll open it up tomorrow and let ya know...
I'll start a new thread in the DIY Test forum. I am starting to build the new and improved Load Bank. Since everybody want's to cobble some shit, I'm jumping on the cobbled bandwagon, hopefully the suspension won't collapse with all the bullshit flying around. Wait till you see MY specs.
