jle
I started a new thread as I had threatened to do, as my 1st set of postings were all about planning, research, pretending that I tidied up the workbench, and getting necessary materials together. I have an early (but not the earliest) PL400 Series 4 4-fin. I secured 8-fin heat sinks with transistor covers, the updated transformer, a new chassis, Watts Abundant's DC protection board, and all the White Oak upgrade kits.
But where do I start?! The question is related mainly to the fact that I have not found a thread where someone does a rebuild that involves a new chassis. My sense is that the general approach removes the control board, upgrades the backplane, upgrade the control board, etc. But I need to start one step earlier (with the chassis). So, here is what I think I need to do:
-Jon
- Install the transformer and heat-sink fins onto the new chassis. The need to add the other chassis hardware will become apparent as I go along (top and bottom, for example). I am assuming that the new chassis then forms the foundation for the rest of the rebuild, and gets built up with the other boards, big transistors, etc.
 - If that assumption is correct, then the next thing to go in would be the backplane boards and the gradual installation and power-up procedures for the transistors.
 - Don's instructions for the Watts Abundant board say that it gets installed first. But a comment from Don that was quoted in Nelson's thread said it goes after the backplane. So I am putting it here in the sequence.
 - Next would be the control board
 - Finally the light board
-Jon
