jle
In the process of revamping my stereo system, I dug out my trusty PL400. It is an early 4-fin Series 1 (the big caps are mounted to the chassis left side wall using band clamps). The exterior is in pristine shape. While the interior looks fine, I have not plugged it in (and don’t plan to without some new caps!).
By way of background, I have been a solder jockey since 1968 when I built a HeathKit stereo receiver. I have done recaps on various pieces of stereo and recording equipment (just starting a recap of a McIntosh C22 preamp and of a Linn Lingo turntable power supply). I built a Moog Synthesizer clone that featured my first (and probably last!) adventure into surface mounting. I only trashed the pads of 1 PCB during that learning process. I built a replica of a Fender VibroVerb amp (from a kit) that worked perfectly the first time I plugged it in.
I use Kester 24-6337-0027 solder, Core Size 66, 63/37 Alloy, 0.031" at 600 degrees (but can go higher if it is needed) and a Hakko FX888D soldering station. I have a Siglent SDM3055 5.5 Digit Digital Multimeter.
This background may be important for my first question below.
I am planning a full White Oak upgrade to include:
Thanks in advance!
-Jon
- PL400 LED Light Board RevC
- PL400-15K-CAP-ASSY-CLMP Capacitor Assembly (that one matches my caps)
- PL400-700 Bus Bar Assembly
- PL400-700 Bridge Snubber Kit (with bridge rectifier included)
- PL400-BACKE-COMP-KIT full comp Backplane Kit.
- PL14_20 RegG1 Dual Mono Control Board Kit.
- The Backplane Kit is described as requiring “very advanced skill levels and more sophisticated assembly and test equipment to be successful.” Based on my background that I described above, should I be tackling this part of the upgrade? I have the “nerves of steel” but also enough humility to know what not to tackle. Thoughts?
- What is the Phoenix Connector Option (for the PL14_20 RegG1) – why would I need that?
- Do I need to order any of the Output Transistors (I am hoping they are already included in the parts listed above)
- Do I need a Watts Abundant speaker protection board or will my speakers be safe enough after these upgrades?
- I do not plan on installing a meter sensitivity switch, so I assume that I therefore have no need for the PL400-LBC-HARNESS. Is that correct?
- Do I need the PL400-700 Backplane Wire Kit? What is it for?
Thanks in advance!
-Jon
