I've set up PL400 #6 to run the above test from the WOPL docs. Before I put the juice to it, I wanted to make sure it is set up the way suggested in the docs. Joe, If you have a minute, could you confirm this is set up right? Thanks! Richard
Richard, It appears that your board is built as full comp by the picture with the exception that you are missing the 1 ohm resistors in the R38R slot (and possibly the R38L slot as well). The debug instructions you appear to be following are for a quasi comp test, not full comp (I am drawing from memory and will have to check that). You are definitely missing a resistor in the R38R slot however.
Yup, full comp. And here is a screenshot of the test set up I am following. Sorry, I should have posted it so you didn't need to go digging.
I'm just trying to out do Gene on leaving R38 out. lol
