I set up 2 meters and a signal generator to indirectly measure the impedance of the zobels at several frequencies. I measured the current through the input of each channel. The following settings were used:
Frequency: 20, 100, 1k, 10k, 20k.
Source Voltage 2.0 volts
Measured A Current (AC Current is a redundant statement. Sound it out)
Instruments: Loftech TS-1 oscillator, Fluke 87, Fluke 87V, Vici micro ohm meter,
Frequency. R Ch. L CH .
20, 24 uA 24 uA
100HZ, 119 uA 119 uA
1K, 1.17 mA 1.21 mA
10K, 11.8 mA 11.7 mA
20k, 24.1 mA 23.3 mA
Resistors measure 5.1 ohm Leftch cap .092 uf, rt channel .095uf.
Mark, you could do the same thing and compare the results. Note that the board does not need to be installed to do this. just inject the signal at the L or R channel. All this does is verify the zobels are functioning.
A note on the instruments. The Flukes have not been calibrated since date of purchase. I have no reason to believe they are out of cal. The Vici micro ohmmeter is $100 or so on Amazon. I really like this instrument and it seems to be accurate.
20, 24 uA 24 uA
1K, 1.17 mA 1.21 mA
Makes you wonder why folks talk about burning up Zoebels?? And why they put that heavy duty Zoebel in the amps sold to Clair Brothers?
A brain teaser indeed. At 350W full power output at 20KHz it is less than 2W dissipation in the Zoebel. Of course, no one is putting out 350W at 20KHz CW anyway...
