They have 15KuF at 80VStrange, I was on the Mouser site and could find the lower voltage caps (18,000 ufd 75V)
We do not know the design intent so hard to guess...Thanks Joe and George for looking. It doesn't look like there's too much choice for replacements anyway. Mouser has a 10,000 ufd 100V that fits. It 85 C temp, 7.5 A ripple, 2000 hours. If I relocate the caps, Mouser has a 12,000 ufd 100V cap 105C, 12.6A ripple, 7000 hours, and lower ESR.
With more ufd or lower ESR, would this be a stress on the soft start resistors?
You have to be concerned with wiring inductance when outboarding capacitor banks...Looks like a good start and idea about opening it up for more airflow by increasing its height.
You can probably relocate any hard to reach test point boards for easier service.
Remember to pressurize the case with your fans rather than exhaust it.
Something to consider is what Dynaco offered long ago for their then monster amps.
Perhaps you could mount the caps in the unused chassis or something else and keep the original Amps dimensions.
https://forums.phxaudiotape.com/threads/dynaco-c-100-energy-storage-system-capacitor-bank.7863/
Beware on those NOS capacitors from a Chinese supplier. Nippon Chemicon is the most common knock off out there. They have the branded shrink wrap and will give you anything you want...As mentioned, I have decided to simply replace the caps and keep the amp fan cooled in it's original configuration. I have ordered NOS NIPPON CHEMI-CON 18,000 ufd 75 V caps a Chinese supplier, the only source of 35 mm dia. x 118 mm available.
Has anyone got a suggestion or link to a good capacitor reforming proceedure?
I would test those capacitors first.Has anyone got a suggestion or link to a good capacitor reforming procedure?
Thanks George. I have already ordered the 18,000 ufd caps from 'overseas' so I will wait for them to arrive to see if I have been bamboozled. I will keep that in mind. I suppose I could always phone Mouser or Digikey too.I've found caps and other parts on Mouser and Digikey that would never populate or be shown by the search engine matrix by directly entering the part #.
Quantities are typically very low, but are in stock, and always ship.
Try entering the caps part #.
