Hey guys, I have an interesting issue I have not been able to zero in on. Sometimes when I turn on the WO/WA 700 S2 (with WO led display), the right meter pegs and the bias on the right board registers zero. A good tap on the case causes it to drop to normal, and the bias returns. It then operates normally. I run the DBT and the variac and I have been stopping the variac at about 45V, which is when the LED meter comes on faintly and pegs. There doesn't seem to be any damage going on at this voltage, but I am hesitant to take it up to a higher voltage while pegged. After I tap the case, and the meter drops to zero, it can be run up to the full 117 V with no issues. I have probed, tapped and inspected as much as I can. After returning the meter to zero, Bias on both sides is typically .355, and there is no issue with the 15V test points.  I'm just trying to figure out what to check in the circuit that could be the cause. Thanks for any ideas and or explanations of how to troubleshoot this.
