I can’t really tell, but you want the solder on the PEM nuts all the way around, make it look like a metal pimple with a concave sloping side. This takes a lot of heat and a lot of solder.Update - not much progress since dogs were occupying garage due to weather. Ordered misc. parts and cleaned up both ends of transformer.
Started backplane work today. Review from the pros - does this look good?
Thumbs up...Update - not much progress since dogs were occupying garage due to weather. Ordered misc. parts and cleaned up both ends of transformer.
Very good, well done...Thanks! The solder pad is covered and there is a slight roll (concave) up to the top of the PEM nut.
I agree with the guys, a little blurry but those two that are in focus look like they are not soldered on the back side, is this right? LOTS of heat and solder as this is a HIGH POWER connection.Update - not much progress since dogs were occupying garage due to weather. Ordered misc. parts and cleaned up both ends of transformer.
It’s also a high stress area- they hold both the transistors and the heatsinks in place, the heatsinks often become a “grab point” when you go to lift it. That being said, be careful with transistor installation, overtightening can pierce the silpads giving rise to a short circuit. A delicate balance…I agree with the guys, a little blurry but those two that are in focus look like they are not soldered on the back side, is this right? LOTS of heat and solder as this is a HIGH POWER connection.
3-4 inch pounds recommended...It’s also a high stress area- they hold both the transistors and the heatsinks in place, the heatsinks often become a “grab point” when you go to lift it. That being said, be careful with transistor installation, overtightening can pierce the silpads giving rise to a short circuit. A delicate balance…
Very good, well done...Thanks for the better view but again, maybe it is a shadow or some flux but these areas look a little suspect
But let's see what the real experts have to say...
