PL 1200 RTA microphone
  • Thread starter Thread starter DJWorm
  • Start date Start date
D
DJWorm
Guest
I have a Phase Linear 1200 RTA in my system but do not have the factory microphone. i would like to have an original but I doubt an original can be found.
Nor can I find the specs on the original. Can anyone access the original microphone specs and/or suggest a replacement? Thanks!
any good condenser mic should work. DBX has a real good one that are cheap on eBay. It will be far superior to the original PL mic
dbx A-256 RTA-M Electret Condenser Real Time Analyzer Microphone
The original RTA 1200 mic had a horrible frequency response in some areas of the spectrum. A lot of compensation had to be done. And that is what the 1200 is going to do, follow the response curve programmed into it...
Lee I did not concider the internal changes with my suggestion
that said the RTA 1200 may be just eye candy from now on as you can buy a whole DBX setup for around $300 and get full control from your phone , iPad or tablet with adjustment out the wazoo
Yep. Although there is value in probably having the 1200 with the rightmic... somewhat rarenow...
There are still originals to be had for the 1200. Just a matter of tracking down the right person…
Have you tried mecadan on eBay?
