Teac X-10R checkout
MarkWComer
Gaston, SC
I was handed this tape deck to give a value for sale. Opinions, anyone? Personally, I wouldn’t go much higher than $400.
Bob Boyer
Chattanooga, TN
You're a little low, Mark. Solds on ebay are running $575 - $700, oarts decks $450 and up. BIN is anywhere from $700 - $1200. I'd guess an ebay auction house would list at $600 or $650.
MarkWComer
Gaston, SC
It’s better than a parts unit, a belt would get it running. The heads, though- are they past the point of getting them lapped? I hate messing with tape decks- buying an alignment/calibration tape is out of the picture for a one- time repair job.
Bob Boyer
Chattanooga, TN
The heads don't look too bad, Mark. They need to be cleaned to be sure but it looks like the guides are the bigger issue. Put a belt on it for the fellow, clean it up and see if he can get $500- $600 for it. If it's in working condition with a new belt and a cleaning, then it should fetch that. Just tell him to be honest - someone may want it for a project, though I'm not sure why. There are much stouter and desirable decks from Teac and Tascam out there - some not too far from that price point. Daily driver 2300s, 3300s, 6300s, etc. can still be found between $600 - $800.
I just think between what you and I saw, unless he wants to sell it as is, parts only, he's leaving a little bit of money on the table at $400.
MarkWComer
Gaston, SC
I haven't seen enough tape decks to make a precise evaluation- and I told my nephew this at the beginning. Tape decks are far too fiddly for me to screw around with, and this is why I hesitate to work on them. The heads looked bad to me and I said so, so I thank you for giving me a more experienced opinion. I'll ask if he wants the belt replaced.
