- Mar 6, 2022
the back of the board has 2 grounds labeled...
one is signal ground...the other
l/r signal grounds also show connected to chassis ground....with continuity check on the fluke...
i was using chassis rail for ground and positive lead on pins 2 and 3 of the two regulators
you should be able to read back writing....
i have 3 grounds labeled on back of board....right signal ground...left signal ground....power ground...you can see power ground goes directly to chassis nut with star washer...Just saw your regulater VDC post. And those readings are the same further out the board away from the regulators, using the ground rail?
