Buy the new chassis and heat sinks and leave the grinding to the chimps
I dunno Perry. You lost half your title there
Yep. I'm doing the new chassis if I ever get around to the 700B build. My 700 chassis doesn't hold screws, someone goofed up holes for the binding posts/rca jacks, and I want that IEC plug too.
I had to drill a hole somewhere in my 4 fin to get something to line up, but I forget. There's a build thread here somewhere......
Joe's chassis have more clearance above and below the backplane boards.Yep. I'm doing the new chassis if I ever get around to the 700B build. My 700 chassis doesn't hold screws, someone goofed up holes for the binding posts/rca jacks, and I want that IEC plug too.
That picture shows an employee drunk on duty, eh Sniff? Even the Accessory AC Jack is installed backwards!
Glad to hear it's working well and thank you for the opportunity in building your project.I can't thank Eric enough for building me this fine piece of equipment-exemplary work and I love the way this thing sounds... I threw in my mostly stock 400 (except larger ps caps,fully recapped and speaker protection) just for comparison,it sounds goods- but it ain't no WOPL...
Eric, question for you regarding the input line. Typically you see a 220K resistor between input and ground and a .47 or so cap in series with the input signal. I notice that you are running "direct coupled" mode and doesn't look like you have the shunt...thoughts/reasoning? I am at that stage of the build and am curious as to why you did it this way.All outputs installed and RG-316 coax connected between RCA's and control board inputs.
Initial Bias set at 350mV after 5 min warmup.
Output offsets measured 0.1mV Left and -0.2mV Right.
The original 700B amps have a switch that allows the user to select direct or capacitive coupling on the inputs.Eric, question for you regarding the input line. Typically you see a 220K resistor between input and ground and a .47 or so cap in series with the input signal. I notice that you are running "direct coupled" mode and doesn't look like you have the shunt...thoughts/reasoning? I am at that stage of the build and am curious as to why you did it this way.
Thanks
