Well... I purchased one off E-BAY. The guy said it was in perfect working order for the $300 bucks. NOT! No Big deal... very clean and not butchered at all!
So... Rear Channels don't work, Ambiance control not working, Volume pot very scratchy and worn out, all switches noisy / intermittent.
I Initially see the ambience circuit op amps not working at all. I temporarily installed a dual LM1458 just get life into it. Easy... 3 pins match, then added the additional connections. Pic attached. Then I find the Ambiance pot totally open, not 5K Ohms. I temporarily wired in a 5K SMT pot and the circuit works. General purpose op-amp, but response is flat to over 20KHz.
OK. Now ordered the Chip adaptors for all the chips (quad RC4136 and dual RC4739), to use the superior OP1602 op-amp. Data sheet attached below. NO DISTORTION AND SUPER SPECS.
I ORDERED THE ADAPTORS WITH THE OP AMPS SOLDERED ON. This may be a drop in, but I will stabilize them if needed. 35MHz Bandwidth types!
I will post pictures and test results when I'm finished with it. Should be a dream clean sounding beast!
Open the pics for all the info for the upgrade in process. Stay tuned,
