Comparing the two boards, all is well and equal for the B+ and B- voltage. Left board, the good one, shows correct voltages at base and emitter of all TO-3s, roughly .380V. Right side bases and emitters are dead. Collectors on both sides show appropriate voltages. As stated earlier, there are no blown resistors or pico fuses on either board. However, most of the resistors on the dead channel show no voltage, even though they all show continuity. The bias transistors test as not blown, but the right side is getting low to no voltage: E - .333V, B - .334V, C - .363V. Left bias transistor voltage: E - 1.43V, B - .777V, C - +1.47V. The board layout sheet I have is for Rev. B. My board is Rev. C. So I don’t have the resistor numbers in front of me, but all those at the TO3s on the right side show no voltage. All caps show same voltage on both boards. Diodes all show same voltage. Bias check pin on right backplane board still reads zero.
