Crown Macro Reference Monster amp rework.
This amp showed up on my stoop with the right channel being dead.
Got another project nearing completion. I tore open the Crown Macro Reference amp open to diagnose the right channel "In Protection" Issue. It had 3 original issue output transistor decided to say screw it and fail with a BE short. The same channel had been "Worked On" before and failed again so I looked a little deeper and found the -15 regulator getting hot which was caused by the 2 resistors in that circuit which are 200 ohm 1/2 watt resistors changing values over the years. One was 90 ohms and the other was 140 ohms. I replaced the resistors with 2 new ones, installed a new 7915CT regulator IC, and doubled up the heat sink along with the fresh thermal compound which had dried up and flaked off. I ordered new outputs and they are out for delivery along with the pre-driver IC's. I'm not one to just find the bad culprits o it is getting 12 new MJ21196G's and 12 new MJ21195G's. I pulled all the heatsinks and put new whale spooge on them, along with the dual Power Supply regulators. All the old stuff has dried out and losing it's mojo. It took me hours to get all the goo out of the holes for the outputs in the heatsinks on both channels. On the control board I cleaned up all the old flux after the resistor and +- 15 volt regs, rework. This amp is a lot easier to work on than the Krell amp being the Crown has an AWESOME Owners/Service Manual. I used MJ21195/96 which have a lower current gain (hfe) but has a higher working voltage. The originals are MJ15003/4 which has a higher current gain but a lower SOA. The originals have a 140 volt rail swing whereas the 95/96's are good for a 250V swing. I'll have to look at the topology of the amp which has a High Side Low Side output transistors so only half of the 12pnp/12npn outputs are working at low listening levels. Maybe one of you experts can chime in as to what you think about the MJ15003/4 and MJ21195/6 swap. I guess I need to look at the plus and minus rails of the power supply to see if it was a good move. The output transistors get soldered in so it's easier to make the decision now. JOE!!!!!!!
I don't know if any of you know anything about these Crown Macro Reference amps but they have a P.I.P. (Programmable Input Programmer) module which plugs into the back of the amp and gives you the ability to tailor the amp to your own preferences. This one has the newest module in it which is a FPX model and that gives you many switchable options to be able to use XLR Balanced Input, RCA input (Quasi Balanced or Single Ended switchable) and the ground lift in case the 3 prong power cord is giving ground loop hum. I guess that helps when you have a preamp with a 2 prong power cord. Most of these amps had 1/4" Jacks on the back for input like some PL 700's, so with this PIP, you no can do 1/4" jacks, XLR Balanced OR RCA inputs. Pretty versatile. I'm anxious to hear it to compare to my WOPL's. It's a pretty rare amp and maybe I'll keep it and pare down to 2 WOPLS. This amp would be handy if it sounds good because I can power 2 sets of speakers down to 2 ohms and the amp will take pretty much what you throw at it. It has the Mono switch on it too but it is nearly impossible to find another one of these to get crazy. This amp, in this configuration, was $4000 with this version of PIP. Its not a real "Looker" but that helped the bean counters keep the price down. It's rated to 760 WPC into 8 ohms, 1160 at 4 ohms, and 1500 into 2 ohms. Switch to mono in either bridged or parallel and that ups the ante to stupid levels. It had VERY good reviews and was seen to be quiet and powerful. This model came with 2 filters on the front and a temp activated fan which is reported to be pretty quiet so you'll hear nothing until the heat builds up, the fan kicks in, and it'll be so fuckin loud you won't hear the fan anyway. The front panel has a switch which controls the backlighting of the "Crown" logo (On or off) and it has GREEN BACKLIGHT!!! My fav.
Pictures to follow shortly.
Let me know what you think about the Output Trans choice.
Sounds cool!
Yeah, I'd be looking for another if the distortion is as low as the wattage is high...
Crown generally made "tools" not "toys" so, maybe a bit more noise than a "fancy" amp, but serious horsepower to deafen a stadium.
Sounds cool!
You can look at the specs, the THD+N was pretty respectable even at high levels.
I would think the only problem would be if it has a V/I limiter circuit and it was tailored to the 15004 SOA. I have changed out the 03/04pairs for the 95/96 combo in a Luxman integrated with no surprises...
I haven't quite figured out the Control Board skizmo yet but I'm reading the theory of operation of that right now. o_O
That should not be an issue as the SOA of the 95/96 is much better than the 03/04 pairs. It will protect earlier than needed for the capabilities of the 95/96s, leaving more safety margin
Here is an inside shot with all but 2 outputs pulled and a shitty shot of the back showing the PIP module. This FPX module is the only one you could use with RCA's. I haven't seen another with that module. You had to use the balanced, or 1/4" phone jacks or use adaptors. This amp has all.
Puerto Rico
The Crown Reference Amps were introduced in the mid 90's and I was in New York at the AES convention when they exhibited it. It's a monster amplifier and comes in 2 versions: Studio and Macro. It has been my main amp for over 10 years now. It broke down once due to electricity problems at home, send it to AMCRON in Indiana (former Crown employees) for repair and a month later it came back like new. Has been working flawlessly since then. Heavy as hell, but very powerfull and stable down to 2 ohms. How it sounds? Crown.jpg For my personal taste and for the $950.00 I paid for it years ago, I can't get anything today, even close, with the same specs.
The Crown Reference Amps were introduced in the mid 90's and I was in New York at the AES convention when they exhibited it. It's a monster amplifier and comes in 2 versions: Studio and Macro. It has been my main amp for over 10 years now. It broke down once due to electricity problems at home, send it to AMCRON in Indiana (former Crown employees) for repair and a month later it came back like new. Has been working flawlessly since then. Heavy as hell, but very powerfull and stable down to 2 ohms. How it sounds? View attachment 74504 For my personal taste and for the $950.00 I paid for it years ago, I can't get anything today, even close, with the same specs.
Very cool. I hope to have mine up and running here in a couple days. One of the things I don't like about the PL is no way to run another set of speakers. This amp is WAY more versatile. What PIP do you have in the back??? I need to find another one of these if it sounds good, I'll call the electrician and get an aux circuit put in utilizing 2 30 amp outlets for the amps. Then I can up the power BIG TIME. :)
