Garnet Gnome
AngrySailor
---not quite right
#30
Was looking at those transformers today, not sure 350/0/350 is correct? I’m getting ~290vac from the good winding no load/diodes lifted. Won’t 350/350 be too spicy? The filament winding is 6.3vac and good. The schematic specifies 515vdc after the diodes...
BlueCrab
#31
So the schematic that was posted shows 515vdc at point A. If this is correct, then the transformer would be 515*0.707 = 364 vac (assuming no load). I think the 350/0/350 would be just fine as tubes will work over a wide spread. However that first cap is shown with a working voltage of just 350vdc - way too low if indeed the voltage after the diodes was/is 515vdc. That cap's working voltage is too low if the transformer puts out 290vac, which would give about 410vdc across that cap.
AngrySailor
---not quite right
#32
290 no load, my field of knowledge is more based toward mechanical engineering, I knew there must be math to fix this
AngrySailor
---not quite right
#38
Back working at this amp. Got the transformer hooked up and checking voltages.
A 448vdc
B 368vdc
C 344vdc
transformer secondary voltage is 300/0/300 and the dropping resistor values are in tolerance to the schematic. I do have new 450v filter caps which I haven’t installed yet but she has some hum. Those DC voltages don’t seem right though. The 350/0/350 would be even worse...
AngrySailor
---not quite right
#40
The amp is on, tubes hot, measurements were taken with no input signal though. The amp works, I plugged my Ricky into it, sounds normal now... didn’t crank it or take any other measurements. Should I be checking bias on the tubes or any current measurements? Seems guys check that shit working on tubes. I’m a t00b n00b...
