Nice looong tonearm with shallow offset- less tracking error!
Going through my remix 12” 45s, Blackbox, Technotronic, Chemical Brothers, etc. Lit up most of the red dots on the WOPL 400 S2. WOPL amps just don’t get tired of pumping. I haven’t pressed the 700 too much cuz I don’t wanna burn my speakers up!Realistically, when is the last time you pushed an amplifier to over 50 watts per channel?
When I was cranking Devin Townsend 'Sonic Mayhem', dust was dropping off the motionless ceiling fan and my Sony TA-N77ES said a final "Farewell!"![]()
Here it is.
Yeah, that track above is from the 'Interlude' side ... which is the more melodic mellow mix. 'No Remedy' from Jelly Jam.
I think it was the track "Numbered" at well over 50% volume dial - that smoked the TA-N77ES. That particular tape gets repeat plays on my system, when I'm working in the home office. I'm pretty sure I was on the 2nd play back of Side B, had turned it up a lot louder and I was sitting in the sweet spot ... facing the rack.
I saw smoke come out of more than one place AND saw the slo-blo fuse pop, all in a split second![]()
If you smoked the amp instead of speakers.....you need more amp....
neil diamond....cracklin rosie....cranked up the time machines (pl400s) this morning....
we are now back in the 70s ....
listening to b.j. thomas...
