HUH???????????????????????????????
How did sound get from the diaphragm in the soundhead to the horn? Was there some kind of swiveling throat? Yes, I like the green felt pads.
The original low mass tonearm...Hello Laz,
It is a very simply horn set-up. The volume is controlled with a cable attached to a lever on the turntable itself, to a felt "ball" that moves in and out of the horn. That actually works well, it can play quite loud if you want it to, and it is clear sound, not distorted. I am adding a picture of the Lateral Reproducer, I just slipped that into the bayonet mount, Using that, and a steel needle, adjusting the speed from 80 rpm to 78 rpm you can play regular shellac 78's from the period. I used to rebuild a lot of these early players, set the diamonds in the Edison reproducers and rebuild them, and did 100's of the regular reproducers, with the mica or aluminum set-up. it's a trip back in time. and fun to experience. Here are some more pictures:
The original low mass tonearm...![]()
It's scary they are so heavy!
At least the stylus is diamond....Those steel needles used on the conventional lateral reproducers of the day still scare me.
I have seen people try and sell Edison Diamond discs that someone, somewhere, tried to play with a steel needle.
They are torn up the minute that steel needle hits the "Condensite" (Bakelite) and the needle digs through the Bakelite, into the wood flour core.
I have both wood flour core, and clay core recordings. With care they are very durable, especially compared to shellac 78"s that
are as brittle as eggshells.
I like Tascam decks too Jim...Studer heads aren’t the best but their transport (when set up properly) certainly is.
I’ve been very happy with Teac/Tascam to handle my tape.
Probably miss that countryside this time of the year too maybe? Beautiful car, love the Mopar.Haaa, this thread didn't stay on track long.......
Here is my linear tracking Mopar..... I miss her
