It is like those magnetically coupled fish tank pumps, no direct coupling. The damping factor sucks in that turntable setup. If you have a torque disturbance of any kind, it will take a long time for the control loop, if any, to counteract it.
There are some of those pumps in the oilfield where a direct coupled centrifugal's mechanical seals have compatibility issues with the pumped fluid. Some designs allow a separate fluid to flood the seal assembly.
My brewing pump as well as my oil burner both use that design. No contamination risk from seal or trapped material in brewing and no risk of seal damage from unknown substances in the waste oil in my boiler. Some solvents will eat seals for breakfast. Learned the hard way. I burn most any liquid that is flammable (EXCEPT GASOLINE) or other low flashpoint fluids unless fully blended with heavy oil. I don't like the BOOM! Unless of course it's intended in my pyrotechnics.
