I test tubes. Nothing pre war though, My B&K tester doesn't have 4 and 6 pin sockets as it was built in the era of color TV. It will test Nuvistors as well.
Funny, the 12AX7 and 12AT7 tubes are used consistently in guitar amps. The 5751 is a drop-in replacement for a 12AX7. The 5751 was designed as a "ruggedized" high mu, dual triode tube with similar specifications as a 12AX7. However, with 30% reduced gain, the 5751 is a fantastic way to reduce the distortion and add harmonic tone to an amp.
Don't discriminate against the indiscriminate substitution of your tubes... That needs a HUH!
The 5751 is wired the same as the 12AX7, the 12AT7 is not wired the same as a 12AX7, those two tubes are non-compatible.
That is beginning to sound kinda like a Herbert Spencer quote.
"There is a principle which is bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance that principle is contempt prior to investigation." Bet you I get a HUH on that one!
