Mike Brosmore
- Jun 23, 2021
Does anyone have the specs on a complete build
Okay… but that’s the 700. I think he wanted the 400…White Oak performance spec
Same exact control board in both, specs are the same whether a 400 or 700Okay… but that’s the 700. I think he wanted the 400…
Thank youWhite Oak performance spec
AAND… With a Yoko Ono record, you could wipe out half of the North Korean army in three minutes!Hmmm… 16kW into an ohm… we’re gonna need more power on the supply side.
So, if an amp produced 1000 watts into 8 ohm load, and we double as impedance halves, we need a lot of power.
1000w/8ohm is reasonable but being able to properly support it is not. The power supply would have to be quite robust and I think a 220v supply would be mandatory.
Probably not the sort of thing you think about Joe, but how would you handle such a challenge?
Parallel amps for each channel might help (four amps for stereo; balanced line in) but that’s complicated. But, even if two amps, I think four chassis will be needed due to power supply mass and heat sink area needed.
Worlds first amp on wheels with remote control to move it? I imagine we’d be over 300# weight per channel.
Edit- remote water cooling. Radiator with fan and a small circulation pump to pull heat away, into another room so the noise of the fans does not distract.
