Hmmm… 16kW into an ohm… we’re gonna need more power on the supply side.
So, if an amp produced 1000 watts into 8 ohm load, and we double as impedance halves, we need a lot of power.
1000w/8ohm is reasonable but being able to properly support it is not. The power supply would have to be quite robust and I think a 220v supply would be mandatory.
Probably not the sort of thing you think about Joe, but how would you handle such a challenge?
Parallel amps for each channel might help (four amps for stereo; balanced line in) but that’s complicated. But, even if two amps, I think four chassis will be needed due to power supply mass and heat sink area needed.
Worlds first amp on wheels with remote control to move it? I imagine we’d be over 300# weight per channel.
Edit- remote water cooling. Radiator with fan and a small circulation pump to pull heat away, into another room so the noise of the fans does not distract.
