You need to be more specific Gene (you are dealing with a bunch of engineers).i have noticed...
on the 8 fin...which has been recapped...
ps cap upgrade...led upgrade...dcp added...
first power on of the day only....produces a noticable hum until the dcp relay engages....has done it since i got it from rob...i kept thinking that each upgrade would eleminate it...it didnt...
it performs as it is supposed to...
ideas???
The speakers hum? They are (supposed to be) disconnected from the amp and shorted to ground until the relay cuts in
Or the AMP hums? If it is the amp, have you pinned down where in the amp it hums?
If you hum it, maybe I can guess which
