Naw, solder them correct. Mock them up, tack solder them, check alignment and fit, finish solder them, and reassemble. You don't want doubt about quality of the job nagging you. It's good practice and you've got plenty of time to tear it down and build it back up. You'll be able to pass this amp onto your son and it'll last and last.
But you know, if some repair guy was replacing a bias transistor, he'd probably just cut it, extract the leads, and solder the new one in. Don't be that guy.
Just use the same care and follow the PDF precisely again. It'll be easier the second time. Just don't get over confident. Hope you've got 16 new silpads and maybe a nice accurate Fluke multimeter from Amazon or wherever. Later! Sitting at home listening to Pete Namlooks' Air 1 and Air 2 digital files on the system. Just amazing.
