The 700 Pro I did the full WOPL on has a factory installed cap on the non wire side bridging the two sets of contacts. Not sure of it's value but probably 0.1 uF.
The switch is marked TV-5, does this mean 5 amps rating per set of contacts? I don't know.
I have taken the attenuator switches apart for cleaning, same switch is used in the PL2000 preamps. Power switch is similar construction. Best to do it in a large clear plastic bag (Jim's idea) as there are spring loaded parts. The contacts may be good, the issue may be in the spring loaded mechanism.
Later today I'll pull the top and bottom plate off the Pro and get you a good photo of that caps value and and orientation on the switch lugs. I presently have that system all tore down.
If it was me, I'd order that 6 amp C&K from Mouser and double the contacts with a cap.
And do the other amps also.
