Gene, if you want to test the transformer and rectifier, disconnect the B+ and B- leads from the storage caps. You could leave them connected if you so choose, but since this is a new to you antiquated old amp, I'd disconnect.
Meter gets set to VDC, ground lead connected to copper buss bar, positive to the B+ wire, then positive to the B- wire. Should be around +80 and -80 VDC if transformer, rectifier, and main fuse are good.
Your going to WOPL the 8 fin, right? Well your going to have plenty of old parts to build the 4 fin with.
it is all taken apart....just a transformer with rectifier bolted to it...no caps ....they are in a box...lol
so connecting it the way you suggest will be mandatory....lol
and i do understand your instructions...even the fuse holders have been reclaimed....of course both rail fuses were blown...lol
well, george....there is nothing left of the 4 fin....seems the back of the pl 14 came in contact with the back plane....there are traces melted off of the pl14 board....someone put two new caps on the board but did not cut the leads...a lots of actual stuff melted....hope it happened near the 4th of july....because i am pretty sure there was a nice light show....maybe even poop stains on the carpet to boot....
the chassis is stripped and ready for whatever....right now it is stopping the door from slamming shut...
i have a new chassis ordered....more wire...light board....cap kit...dc protect board....
i bought the big rectifier in the original kit from joe...and it is snubbed and ready for installation....i will make an aluminum bracket to hold down the big caps....as the original 4 fin is wall mounted...both machines i had delivered today were either double face taped in place or a big glob of silicone to hold the big caps in place....i think its better to make a bracket...please send a pic of how you mounted your rectifier and the bracket that holds down your caps....did you put a cushion or something underneath ???  or are the caps just held against the cradle on the transformer....
so all i really need is working meters and a transformer....i am going to use the faceplate off of the 4 fin...it is the ugliest and really work on it...
i want an oak tree image between the meters with maybe 400 watts rms in some nice script across the bottom....or some words of wisdom printed on the face....i will rebrush the aluminium....i have my 4 fin that is my daily driver available for swapping parts too...the meters in that one have honeywell written on them...these 4 meters i have look alike with no writing...no clue what that means...i will have 4 machines to make a really nice wopl and 2 other working 400s....if i get lucky and plan this out....
all of my meters are tinted....i am disappointed in that...but, maybe the yellowish lights will look nicer than the clear....it has a not so attractive shadow from the needle....and the tint seems to dramatize that...i will have to listen to joe on that....he was betting the 8 fin was not tinted....well, its tinted...
lol
i still have your board that you donated to the cause for parts if necessary....i did reorder the transistors i robbed from it....
and now for your viewing pleasure....
